Display the authenticator statistics to manage network performance.
Use the clear-stats command to clear EAP or NEAP statistics.
Switch:1#show eapol auth-stats interface
================================================================================ Eap Authenticator Statistics ================================================================================ PORT EAP AUTH-EAP START LOGOFF INVALID LENGTH LAST-RX LAST-RX RCVD TX RCVD RCVD FRAMES ERROR VER SRC -------------------------------------------------------------------------------- 1/1 716 1074 0 0 0 0 1 18:a9:05:b1:04:ce 1/2 0 0 0 0 0 0 0 00:00:00:00:00:00 1/3 0 0 0 0 0 0 0 00:00:00:00:00:00 1/4 0 5 0 0 0 0 0 00:00:00:00:00:00 1/5 0 0 0 0 0 0 0 00:00:00:00:00:00 1/6 0 0 0 0 0 0 0 00:00:00:00:00:00 1/7 0 0 0 0 0 0 0 00:00:00:00:00:00 1/8 0 0 0 0 0 0 0 00:00:00:00:00:00 1/9 0 0 0 0 0 0 0 00:00:00:00:00:00 1/10 0 0 0 0 0 0 0 00:00:00:00:00:00 --More-- (q = quit)
Use the data in the following table to use the show eapol auth-stats interface command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
